I threw a stud into my front heat exchanger . the sled overheated to the point where the light sensor that came on ,then went out. thinking it was good i kept going untill it started bogging out .i then shut er down to find a ton of oil in the air filter and very low on oil. towed er back to cabin . next morning wouldnt start after putting oil back in and coolent, finally started ,but only could idle. for a min . or so .It got so hot it deformed the dipstick to the point i couldnt pull it all the way out. also cant get the plug wire to come off .i wanted to check plugs , thinking to change them . Im afraid i fryed the thing , what do you guys think?
