2007 Attack - no spark
ok so I'm a moron...I was check the wrong side of the plug. When I check the resistance of the 2 wire plug (black plug) going to the stator with my dial set at 2000k I get a reading of 130
I would go ahead and change the pickup coil, or entire stator as some suppested - its up to you.
This was fairly common on 07 Apex.
I have the same problem just order a stator from Kimbex I really hope that will be the fix
