Mountaintech
Problem solved. Sat outside in the cold all day. Cranked 5 revs with fuel pump off, turned fuel pump on and it started 4 revs later. I'm installing a weatherproof push button NC switch.
Not really doubting you but every year at this time these starting issues get brought up and then it seems like they go away for the rest of season. Coincidence? No. I believe old gas in the system is the reason or people just learn to have confidence that it will start. That said I do have a Power Commander with a tune for stock. It is a very little bit leaner than stock. Before the PC I leaned it out using the stock diagnostics. Might be something to try since after 11883 mi my plugs although worn were a perfect tan all the way down. Never fouled a plug and never changed them till this year.
Mountaintech
If I don't disable the fuel pump for the first 5 revolutions I won't even get a sputter for 20+ revolutions. That is in a warm shop. The difference is clear.
Mountaintech
cannondale27 said:Not really doubting you but every year at this time these starting issues get brought up and then it seems like they go away for the rest of season. Coincidence? No. I believe old gas in the system is the reason or people just learn to have confidence that it will start. That said I do have a Power Commander with a tune for stock. It is a very little bit leaner than stock. Before the PC I leaned it out using the stock diagnostics. Might be something to try since after 11883 mi my plugs although worn were a perfect tan all the way down. Never fouled a plug and never changed them till this year.
Do you have the original ECU?
Yes I do.
Mountaintech
The scenario I am talking about involves the original 07 "00" ECU.
stingray719
Mountaintech said:If I don't disable the fuel pump for the first 5 revolutions I won't even get a sputter for 20+ revolutions. That is in a warm shop. The difference is clear.
I believe you about the fuel delivery before ignition. My turbo Phazer was especially ugly starting before ECU update. Had to crank with throttle part the way cracked to get it going. All 3 of my Phazers now have the update and start correctly now.
Mountaintech said:The scenario I am talking about involves the original 07 "00" ECU.
I have had the Original ECU in the whole time. Is no doubt the updated one starts it better. Just saying there is some alternatives.
stingray719
cannondale27 said:Mountaintech said:The scenario I am talking about involves the original 07 "00" ECU.
You were lucky enough to get one that does start, and I suspect your power commander helps alot. I have a stock ECU from a 2007 Phazer I can send you I gurantee will give you starting fits if used without a power commander....
swixtt
- Dec 9, 2013
just got my new 10 ECU in the mail. i'm sure hoping it helps with my start issues.
mine sputters as well and won't start at all when it is really winter out. the major problem i have with these Phazers is i leave it sit the day after getting into the backcountry... i come back in the late afternoon and sure hope that it starts. if i just rode it all day i wouldn't really mind it so much.
swixtt
- Dec 9, 2013
well. this completely resolved my issue for anyone reading this. the new ECU was the magic fix and had a good test on Sunday morning with -15c temps!
now i'll go and tell the dealer how to fix this problem. they told me all sorts of things but didn't believe the ECU was the fix.
stingray719
swixtt said:well. this completely resolved my issue for anyone reading this. the new ECU was the magic fix and had a good test on Sunday morning with -15c temps!
LOL! How could the dealer NOT believe it when there was a service bulletin on it? WOW.....find another dealer?
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
of course the dealer would rather tell you to go change your spark plugs or its bad gas than try and do a factory fix and try and get money from Yamaha and the service bulitin expired many years ago anyway so it has to be out of the goodness of their hearts to do this fix. I got the the same crap when I tried to get this one fixed on my 07 it still absolutely will not start on its own below 5degres F. I have to jump start it every time
swixtt
- Dec 9, 2013
definitely get that new ECU Sparky. it is almost worth keeping now
no other Yammy dealer around here.
gotta say a big THANKS to this thread to help in solving the problem.
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
Yea I just ordered the kit and hell with it I am going to put the springs in too.
