skibabr
- Mar 12, 2019
- waterford, new york
- 2009 Nytro
I noticed the engine was ticking slightly after a ride the other day. I was wondering if anyone knows the cause. Could the valves need adjustment. the sled has about 3000 miles on it and I changed the oil and filter about 300 miles ago. Any help on this matter is greatly appreciated.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Probably the exhaust
skibabr
- Mar 12, 2019
- 2009 Nytro
I changed the exhaust gaskets last year with the copper ones. I'll check a couple things when i get home. Thanks for the reply.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Maybe a pipe is cracked? Should'nt need a valve adjustment till around 20k miles i think. Another thing it may be is your clutch. On those 3 cylinders the clutch seems to make some noise.
skibabr
- Mar 12, 2019
- 2009 Nytro
Ok, thank you. I'll check that out.Maybe a pipe is cracked? Should'nt need a valve adjustment till around 20k miles i think. Another thing it may be is your clutch. On those 3 cylinders the clutch seems to make some noise.
