Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Anything is possible. This is how you check the stator.
Also check if any of those stator wires are shorting to ground.
Mattcull
- Aug 27, 2020
- New liskeard
- 2009 Yamaha venture lite
I did a running test on the stator and got 48,48,42 voltsAnything is possible. This is how you check the stator.
Not good I’m guessing .
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Manual says to check resistances and shorts to ground.
Mattcull
- Aug 27, 2020
- New liskeard
Not sure how to check shorts to ground and I don’t think my multimeter is sensitive enough to check the resistanceManual says to check resistances and shorts to ground.
Mattcull
- Aug 27, 2020
- New liskeard
Btw, do you how I could get my hands on a manual? I think it may come in handy. Thank youManual says to check resistances and shorts to ground.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Although it's for 2007, it's pretty much the same.
http://www.mediafire.com/file/yimocy4ntmn/2007_Phazer_MANUAL.pdf/file
This video is pretty good showing how to check the stator in the vehicle. I Skipped the part for single phase stators since ours are three phase. You don't need an expensive meter (I have one from Princess Auto), just one that can read resistance Ω
Easiest place to do this is at the voltage regulator connector. It's the three white wires. Just unplug it and do your tests from there.
Mattcull
- Aug 27, 2020
- New liskeard
k so I measured the resistance and got 0.3 all across.
checked for grounding and i got the audible sound across all three.
So..I'm guessing this means its not good correct?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Looks like it's a little out of spec for resistance but if the windings are shorting to ground, it's not good. Just to confirm, you had one probe on ground and the other at each of the three wires?
Mattcull
- Aug 27, 2020
- New liskeard
Yep. one to ground and the red I put to the three wires. Now my meter doesn't read anything when I do this, I do get a beep. But, we've been driving with the headlight not plugged in and it seems ok...for now. I have ordered a new stator.Looks like it's a little out of spec for resistance but if the windings are shorting to ground, it's not good. Just to confirm, you had one probe on ground and the other at each of the three wires?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Maybe your meter wasn't in the proper range but the continuity beep pretty much confirms it. There should be nothing to ground. If you ride with it like this, it could get worse and leave you stranded if you don't get enough power to run the ECU. Bring booster cables with you so a buddy could charge up your battery for you.
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
Sorry for reopening this thread, but did a new stator fix the problem? I’m experiencing the exact issues. 12.6v on fully charged battery while running and at 5000rpm. Unplug the lights and it goes to 14volts even at idle. 0.3ohms across all white stator wires. All have resistance to ground like 2ohms or higher.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
There should be nothing to ground so I would say your stator is bad and shorting to ground.
- 8K
- 8K
