justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
Ok but most shop air compressor only goes to 120psiGive the Mega Float a try if you have already purchased it but you will need to run 180 to 200 lbs in it and with the fox manual pump your arm will fall off to get it set to that. Use a compressor and then is the manual pump to back it down to the setting you desire.
https://www.globalindustrial.com/p/...flator-cc2300-12-or-120v-300-max-psi-24l-hose
I used something like this. Then I could use the 12 V accessory plug to pump it up.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
That's a good idea . Didn't realized they would pump that much psi. Coolhttps://www.globalindustrial.com/p/...flator-cc2300-12-or-120v-300-max-psi-24l-hose
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
GYTR's For front are better than floats.
