Jason.Benjamin
2015 Viper starts but wont stay running until warmed up.
I can get the Viper to start but I have to keep the throttle crack open just ever so slightly until she has warmed up.
(like literal almost resting my hand on the throttle paddle)
It was like this all last year running premium gas even after a few tanks worth.
Is there a micro switch in the throttle housing that could be bad?
Or something else to look at? ECM flash?
I have seen similar posts but slightly different symptoms.
I am thinking she should get spark plugs Regardless are the certain plugs recommended?
We had this happen on our Winder but once I brought the machine in the shop and got it thawed out it went away.
Check your throttle free play.
Jason.Benjamin
Sorry this doesn't mean enough to me on what to check or adjust….Check your throttle free play.
I understand what the throttle is after all it is the go fast switch.
Just dont know what the correct amount of free play should look like.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
Also might be your idle speed sensor. But you will need the service manual to check it and all the other sensors. Basically I wouldn’t work on a sled unless I had the specific service manual. I don’t have a viper manual just a nytro one
RobX-1
- Coldwater, OH
That's one of the nice perks of supporting this forum and becoming a VIP member; VIPs, get access to the service manuals.
With very light touch on lever a credit card should slide through gap between lever and block.Sorry this doesn't mean enough to me on what to check or adjust….
I believe even the owners manual shows throttle play adjustment.
Jason.Benjamin
Just a section about throttle ignition monitor switch. Which does really tell you how to test or adjust Anything.I believe even the owners manual shows throttle play adjustment.
In the service manual is there better instructions to test things and adjust them?
Not sure. The adjuster is on cable under the rubber tube attached to riser. Check and adjust if needed.Just a section about throttle ignition monitor switch. Which does really tell you how to test or adjust Anything.
PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
If you have 7k miles or more it’s time for exhaust valve clearance check. Tight exhaust valves affect cold starting.
Jason.Benjamin
It will run for about 30-45 seconds then on restart I have to hold the trottle open enough to keep it running.
New Iridium eix plugs go in this week.
I know I have flooded it a few times on 2nd start.
PAvector
- Feb 24, 2007
- Pennsylvania
I wouldn’t try any more until you get new plugs in. Your risking a kickback taking out the starter, two gears and the stator/stator wheel…over $1k damage.
Jason.Benjamin
Plugs swapped
starts easier but still runs for 30 seconds then idle drops down a good amount and stalls.
Restarts eaisly but will not keep idle until it is up to ~95 temp
9900 miles on the sled, not that I know how many on these plugs.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Your valves need adjusting.
Lucky you made it that far before needing an adjustment.
Mine got tight at 6500 miles.
Just one of the many things to deal with when running a 4 stroke.
