Here is the Video of the install:
Step by Step information how to install EPS (Electronic Power Steering) on your Yamaha Sidewinder 2017-current that don't originally have EPS.
There are 2 PDF's (PNG) shown, one is the info needed for you to build your own harness and the other is a the final parts lists needed with Yamaha part numbers and Cat part numbers for ordering all show at retail pricing. Most dealers and websites will give 10-15% off. If anyone is interested in my harness for quick plug and play installation or for me to do the installation for you please message me. Remember installing these in a timely matter is all based on availability of parts.
Update 11/5/24: After further review on our new 2025 EPS Sidewinder, you could reduce the size if the main harness wire to 12ga for main power and ground as well as change the trigger power wire to 18GA. I have updated the attachments.
If you want to split your power source there is a 2 outlet splitter #1639-623 and 3 outlet splitter #1639-624
Update 3/6/2025
Update 3/6/2025
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Two Gold Stars!! Awesome work
Thank you !!Two Gold Stars!! Awesome work
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Now if only there was a way to retrofit Apex/Vector power steering motors. I have a pile of them sitting around.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I have never seen one, what do they look like. As simple as the EPS is, I am sure that it can be done as long as their is room.Now if only there was a way to retrofit Apex/Vector power steering motors. I have a pile of them sitting around.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Nicely done Tom. Pretty much exactly how my install went. I did not move the plate for the brains on the right side though.
Great!! I was worried about wires rubbing. Could always just zip tie a hose on that bracket edge too.Nicely done Tom. Pretty much exactly how my install went. I did not move the plate for the brains on the right side though.
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I should look at that a little closer just to be sure. Thanks!Great!! I was worried about wires rubbing. Could always just zip tie a hose on that bracket edge too.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Very nice Tom! This should give me the confidence to do this!
Awesome!!Very nice Tom! This should give me the confidence to do this!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Are you saying you are building harnesses to sell?If anyone is interested in my harness for quick plug and play installation
EXCELLENT video!!!! Kudos to your camera person. That is the way these DIY videos should be done.
Another reason why this site is the best.
I have enough material to build and sell a few.Are you saying you are building harnesses to sell?
Turboflash
- Mar 18, 2019
- Southern MN
Amazing!!! Thanks you!!Here is the Video of the install:
Thank you guys. Spread the word. We could use some more traffic, thought this might help
Vtudderdelight
- Nov 4, 2024
- Vermont
- 2020 Thunder Cat
I would be interested in the harness you built. You mentioned you have a few that may be available?Thank you guys. Spread the word. We could use some more traffic, thought this might help
Thanks!
