earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The common parts noted were simply there to say that they are not special order and you may already have them. In the translation from the parts catalog to everything required there are a lot of parts that are already there or are not unique to the EPS mod.What is the point of the X's in the column of "Common Parts" then? I was under the understanding that those parts were already on the sled and were reused. Is that not true?
Here are the harnesses I am making. $150 plus shipping and if you need a splitter for the flasher is another $30.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
$180 for all?
Correct, plus shipping. I have more parts coming so for more harnesses.$180 for all?
I am all restocked on parts to build more harnesses. Let me know if anyone needs one.
john928
- Feb 2, 2024
- NJ
- 2017 Thundercat
One correction to the parts list. The Cat part number for 21 is 2623-202.
Ill get that updated. Thanks for the catchOne correction to the parts list. The Cat part number for 21 is 2623-202.
Updated on first page!! Also Cat is starting to shop Back Orders. I just received my parts needed to finish up 2 EPS installs.One correction to the parts list. The Cat part number for 21 is 2623-202.
john928
- Feb 2, 2024
- NJ
- 2017 Thundercat
Glad to hear they are shipping the Back Order stuff! I was just informed a few days ago that a few items of mine are being pushed out a bit further. Not a big deal as long as they eventually ship in the next few months. This is a Spring/Summer project for me.
| Part Number | Qty | Description | Backorder Date |
| 1705-667 | 1 | EPS,PROGRAMMED-G7 ASSY V3 | 3/23/2025 |
| 1605-212 | 1 | BRKT,BTM MNT-EPS | 4/6/2025 |
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Hopefully they don't keep pushing out the date. They did that to me for a center shock spring. After getting pushed out 3 times, I just cancelled it.Glad to hear they are shipping the Back Order stuff! I was just informed a few days ago that a few items of mine are being pushed out a bit further. Not a big deal as long as they eventually ship in the next few months. This is a Spring/Summer project for me.
Part Number Qty Description Backorder Date 1705-667 1 EPS,PROGRAMMED-G7 ASSY V3 3/23/2025 1605-212 1 BRKT,BTM MNT-EPS 4/6/2025
Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
Is there any chance this would work on a 2016 viper or a way to make it work? I need EPS due to a shoulder injury but can’t justify the cost of a sidewinder with how little I get to ride. So debating picking up a Viper. Otherwise I will retrofit all the newer parts onto my Attak. Travis cold probably help me with that if that’s what I do.
Yes it can be done. Few different things you have to do to get it to fit includes modding airbox and different location for voltage regulator.Is there any chance this would work on a 2016 viper or a way to make it work? I need EPS due to a shoulder injury but can’t justify the cost of a sidewinder with how little I get to ride. So debating picking up a Viper. Otherwise I will retrofit all the newer parts onto my Attak. Travis cold probably help me with that if that’s what I do.
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I installed it on my 2016 Viper, and it works fantastic!Is there any chance this would work on a 2016 viper or a way to make it work? I need EPS due to a shoulder injury but can’t justify the cost of a sidewinder with how little I get to ride. So debating picking up a Viper. Otherwise I will retrofit all the newer parts onto my Attak. Travis cold probably help me with that if that’s what I do.
See post #271 in the "EPS conversion?" thread to see a pic of my modified air box. You will also find lots of other useful information in that thread.
john928
- Feb 2, 2024
- NJ
- 2017 Thundercat
I now have all the parts needed sent from Country Cat EXCEPT for the EPS,PROGRAMMED-G7 ASSY V3
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
That's my hold up with ordering parts. All of the small parts mean nothing if you can't get the actual EPS unit.I now have all the parts needed sent from Country Cat EXCEPT for the EPS,PROGRAMMED-G7 ASSY V3![]()
