Moodeyblue
the Yamaha rep at Haydays told me 14.5 rollers. He also said the helix hasn't changed....
looking forward to the confirmed measurement on the rollers.
krm
- Apr 22, 2016
- ny
I was using 15 mm rollers all last season with no roller issues .When you stop for a break ,let some air in the sled .And ck.things .
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
14.5mm rollers, took one out and measured it this morning.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Can you post exactly what has changed from 18 to 19, then somebody can just go and order the new parts. I know it has already been stated each part in different posts, it would just make it easier for someone to order
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Helix:
2019 = 35-39
Secondary Spring:
2019 = Pink
This is all I can tell from the spec sheet included with the SRX we got. Will know more after tech update school.
2019 = 35-39
Secondary Spring:
2019 = Pink
Joshua
- Apr 14, 2010
- Newfoundland
Helix:
2019 = 35-39
Secondary Spring:
2019 = Pink
Thanks a lot!!!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Is that what the 2017 models for lower eleavation have as well.14.5mm rollers, took one out and measured it this morning.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Sorry I found it,yes it is....thanksIs that what the 2017 models for lower eleavation have as well.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi Ken,do you mind saying where you picked up your 15mm rollers from. thanks peteI was using 15 mm rollers all last season with no roller issues .When you stop for a break ,let some air in the sled .And ck.things .
fourload
Looks like it will upshift quicker and have quite a bit less belt pressure in the secondary with this spring/helix combo. This spring is less torsion and compression than last years stock spring. Probably they found a more efficient cooler running combo.Helix:
2019 = 35-39
Secondary Spring:
2019 = Pink
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Posted this in other thread too....
Good info.
SRX Clutching.....
With lighter pink sec spring, and rev 39/35 helix, it seems YAM wanted to lighten up backpressure.
Do we know what the rivets sizes are in the weights? Are they same as previous yrs?
Also, can you check on what the secondary settings are, as to which numbers/degrees spring is set at(IE: 6/1)
Dan
Good info.
SRX Clutching.....
Dan
krm
- Apr 22, 2016
- ny
Yamaha dealer .Hi Ken,do you mind saying where you picked up your 15mm rollers from. thanks pete
krm
- Apr 22, 2016
- ny
14.5mm=8gf-17624-00 15mm= 8gf-17624-10 15.6mm-8gf-17624-20 16mm= 8gf-17624-30
Byam
Previous primary weight are fully loaded 3x4.5gr per arm Still the same?
The secondary "stock" on 17-18 doesn't closed and backshift realy well......
I don't understand the softer spring for 2019:-/
fourload
Stock Sidewinders could barely pull the stock clutching until well broken in. Back shifting wasn’t the greatest also. The steeper helix and weaker spring will only make things worse. Maybe the rivets are lighter in the weights? Maybe the 1 inch track is way easier to spin?Previous primary weight are fully loaded 3x4.5gr per arm Still the same?
- 9K
