2019 Winder Idler Wheels
Often it's the 25mm ID that is most important, as that fits the spacer or stub or axle, etc. The bearing OD and width often aren't as important as those are part of the wheel. 6005 is 25mm ID x 47mm ODx 15mm width. 6205 is 25mm ID x 52mm OD x 15mm width. Tricked Toys makes 8" billet wheels that use 6205. http://www.tricked-toys.com/store_wheel_bullet.php.
6005 is thinner than 6205, Making the wider portion hang off the out side of the axle, dont know if that would be an issue with wheel positioning on the track, the spacers could be trimmed for the inside wheels.
Hey everyone...
Surfing the thread today and thought i'd throw this out there.
Did anyone with a 2019 winder have any issues with their idlers breaking? All 6 of mine are TOAST!! Not worn out... actually broken right off!!
5000km season. I talked to my dealer who put in a warranty request. Yamaha said "he has studs, we will not cover that". All my studs are torqued and checked frequently. Definitely not studs. Also, what's their excuse for the outside of the skid?? I dont have studs there! The '19 wheels are definitely not as beefy as previous years. They have little contact with the outside rubber.
Not sure what to do here. They are relatively cheap to replace, however I don't want to have to go through this every season. I am considering putting a full set of 2018 wheels on which are a much more robust design.
2 questions...
1. Why did this happen?
2. Replace with 18 or 19 wheels?
side note... rear axle wheels are not looking that great either. Only the top skid wheels are still in good shape. Likely because they are solid.
Hope everyone is having a good summer!
View attachment 148847 View attachment 148848 View attachment 148849 View attachment 148850 View attachment 148851
We just came out with the super duty idles with the larger bearings. Will be a one time purchase!!
$40 ea.
JT Products
8105450066
$40 ea.
JT Products
8105450066
thanks! Will the work on the inside of the skid?
Yes, all but the rears and the top two.
Todd
Well I seem to only get 1 season out of the center two wheels. They are chewed again likely from stud heads . How do you figure your wheels will handle that abuse? Thanks Todd
Our new wheels are made from the same material that out big wheel kits are made from. W have had no problems over the last 8 years.. Plus the wheel has a wider contact area to be more durable.
