2020 sidewinder
thunderbolt
ontario, canada
Has Yamaha addressed any of the issues with the past sidewinders , for example over heating if left idling for more than 10 minutes or in hard packed trail or lake conditions , and how about clutching and belt blowing , has any of these issues been addressed by yamaha
You shouldn't have to install scratchers and a fan set up on a 20000 dollar machine , and start playing with your clutch
I love the sidewinder but really have to start changing stuff right of the bat
Nope! Nothing has changed! Lots of bandaids out there. Plan on spending an extra couple g-notes on top of your 20k !!
But feel the arm stretching power and you’ll see what all the fuss is about. Just don’t tally up your $/per mile!
Like I said I love my winder 2017 and now my new one is in just wondering if anything got resolved in regards to previous years
Luckily most of what you have on your ‘17 will bolt on your ‘20
Yeah I hear you, I thought they were going to address lots of stuff on the second year of production (2018), but whereas there was many items that could have been addressed but were not, I figured they would keep it as is instead of opening up a can of warranty worms! Have used my warranty quite a few times threw my dealer though, and he made sure I had the 5 year deal for cheap. So really not much to complain about for me!!
I've had zero issues with the updated clutching on my 2019 - I also think belts are biased a lot on how you handle the sled (of course you're going to blow a belt if you're full throttle and aggressive from a dead stop).
The cooling issue hasn't changed - but again, I've had one issue since owning the snowmobile (I see absolutely no reason to let your sled idle for extended periods of time).
X2 need to shut them down when waiting for everyone to catch up
Being the environmentalist that I am, I would like to see a shut off built into the software on these machines. If the engine is at operating temperature, then any idle for about 30 seconds or so would then result in automatic shut down.
I know most of us are capable of this ourselves, but machines left idling excessively still happens.
They need to idle more than 30 seconds too cool the turbo down after a hard pull ,plus when you shut the engine down it needs to sit for 5 - 10 minutes to get rid of the heat before starting again IMO
It also happens when the trails are hard packed but just not as quickly
X2 Fast. I ALWAYS let mine idle a minute or 2 after hard pulls to allow the turbo to cool down. Not sure where, but I've read it's really hard on turbo to shut it down when it's piping hot! Good recipe for failed bearings!
