justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I did not trim the outside of it at all.
Installed my BOP's oil tank gasket over the summer. Rode the sled this past weekend, no leaks.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
How is the bop gasket holding up for everyone. Is it the solution. I’ve resealed a lot of tanks with the best stuff and after a year or two they all leak. ( or almost all).
I’d love to hear some real world experience with the bop gasket.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Going into 2nd year with mine after 1500 miles last year and no leaks. Usually when pulled out from summer storage I always had one using Yamaha yamabond.How is the bop gasket holding up for everyone. Is it the solution. I’ve resealed a lot of tanks with the best stuff and after a year or two they all leak. ( or almost all).
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
One full season on mine,no leaks
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
About twenty minutes run time so far! No leaks. Lol. That’s about to change in the next 10 days.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I'm not sure what the best stuff is, but I used regular old Ultra Black silicone years ago and all is still fine 5500 mile later and still going strong. Funny thing is I just put the sealant on the tank and tightened it all right back up, didn't wait and then torque down after it set a bit.
Somewhere on TY a fella reported his BOP rubber gasket went brittle and leaked out the oil very quickly and rapidly, somewhere around 2500 miles or so. Its the only report I've seen like that.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
BOP gasket. I cut..
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Any change or new recommendations on what sealant to use?
I order a gasket from Travis but something happened with the shipment and not sure where it is.
I would like to leave for sledding this Thursday
KnappAttack
- Feb 19, 2004
- Welch MN
Permatex Ultra Black has been good for me for 6000+ miles.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Perfect thanks
I will do that tomorrow
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Be sure to follow the directions for the sealant. You do not want to tighten the bolts until the sealant has cured for a number of hours first. Just barely snug them and let it sit for the recommended time before torqueing them down.Perfect thanks
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Will do
I guess I will pull them out one by one after cured and loctite them
Turboflash
- Mar 18, 2019
- Southern MN
Critical to degrease/clean both sides!! No residue. I use acetone.Will do
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I used Permatex Right Stuff after my BOP gasket blew out from a frozen ROV and frozen bypass (my fault). Only 1 trip and ~300 miles so far and good to go. Also deleted the ROV so I shouldn't have any issues going forward.
