PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
I have never used the STM weights so I am not comfortable commenting on how to set them up.
I can say that with Daltons set to 80 grams, 35 degree helix with Cat green at 0-1 I have gone 1500 miles on the same belt. XS825 Ultimax. 270 tune.
Offset with the Hurricane bar and I allow it float out 2.5 mm.
What is your offset?
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
What is your offset at?
58.7mm is my offset
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
58.7mm is my offset
Thanks!
Like clutchmaster said, not all sleds are the same. On my ‘17 winder, I didn’t machine for offset and got 3800 miles only blowing 1 belt. My offset was around 60mm.
My offset is currently 57.5mm on my ‘19 and feel I should come back the other way towards 60mm.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Get those weights straightened out first. 7 grams in the tip is too much. Move it to the heal.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Just under 58 mmWhat is your offset?
Lusemeat924
- Jan 1, 2016
- Drumbo, Ontario
- 2018 Yamaha Sidewinder 137 XTX SE
Which Dalton weights?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
DTYA-1Which Dalton weights?
theewarrior
How much weight do you run?I have never used the STM weights so I am not comfortable commenting on how to set them up.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
80 grams
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I did around 1200-1500km whit dalton white! Always xs-825 (new timken) realy realy hard on sheaves a LOT more than the old one :-(.
Belt temp is very good and the sled have now a very good pull down low and in the midddle.
BIG BIG downside..... my sled eat primary roller for breakfast and i am
tired of it.
I just came back from a 900km in 2 days. Fast trail riding, my oillite primary bushing are already shot....
I am about to change this cheap clutch
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I'm no metalurgist but i think oil lite is too soft for this appl. You can however get harder oil lite material.
Mototown
- Sep 11, 2018
- Apex 40 th
That’s where I’m at , I chewed up a brand new set of Yamaha 14. 5 in 400km of fast trail riding . With the setting it’s on par with apex quality throttle response with big power on top end but won’t lastI did around 1200-1500km whit dalton white! Always xs-825 (new timken) realy realy hard on sheaves a LOT more than the old one :-(.
BIG BIG downside..... my sled eat primary roller for breakfast and i amtired of it.
Mototown
- Sep 11, 2018
- Apex 40 th
I went back to 6-2 wrap on B/orange secondary last night, it’s not anywhere close to what is was .
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Back to 6/3 - b/o for me......it ran great with this and cooler clutches, ultimax all fine so far.
Main reason is I did not see any big difference with bigger white except more heat on my type of trail(270) and lake(240) running. So i'm opting for less pressure on m TP rollers in aim to last as long as possible.
BTW near 2400 miles on TP rollers now, all good still. I do run less helix then many of you with red primary/2 glide washers and 77.3g.
Dan
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
660 bearing bronze is harder, ampco 18 or higher is really hardI'm no metalurgist but i think oil lite is too soft for this appl. You can however get harder oil lite material.
