viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
Just wondering what peoples thoughts are on the 4th wheel kits.
I think they provide better traction and handle better through the corners.
But i have noticed its a bit harder to side hill. The track is defiantly easier to adjust and center in skid.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Yes. If for nothing else, it keeps snow and water from hitting you in the back!!!!!
I had to cross a large shallow water hole once and the water caught the edge of the track where there was no wheel and covered my back with water!!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
If your studed, especially on the outside then. 4th wheel is almost a must, if not then throw in a jt 2 whell trihub replacement, easy to carve, sidehill and just plain looks cool with no wheels on outside
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
You got a double post bud, try to notify a moderator to consolidate all replies into one.Just wondering what peoples thoughts are on the 4th wheel kits.
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
Trihub sucks because it has the potential to leave you stranded. Just for that a 4 the wheel kit is worth it
kyzer
I just picked up the J@T Tri hub replacement. Looks like a nice upgrade, good quality parts. I am going to try 2 wheels for a bit, planning on studding then I will put 4 wheels..
Really only need the 4 for studding if you do the outside of track. If just middle like I do outside wheels would not be needed other than for longevity and backup if one of inners fails.I just picked up the J@T Tri hub replacement. Looks like a nice upgrade, good quality parts. I am going to try 2 wheels for a bit, planning on studding then I will put 4 wheels..
Alsim
- Oct 6, 2014
- LTX SE 2018
No studs and changed bearings each begainning of winter, no issue for me with the trihub since 3 years
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I bought the 4th wheel kit and have a hard time getting the track alignment right with it. I've thought about making up an axle to use the new wheels instead if the the tri-hub. I have to admit that I like the look of no outer wheels and I don't trust the bearings in the tri-hub.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
No one talks much about other options, but there is also the Big Nutz axle and three wheels inside the rails for those that want more than just two wheels in the center for peace of mind without having to add outside the rails.
viper strike
- Dec 22, 2016
- belle plaine mn
I like how you removed the black stop blocks, you ride like this in stock configurationNo one talks much about other options, but there is also the Big Nutz axle and three wheels inside the rails for those that want more than just two wheels in the center for peace of mind without having to add outside the rails.
Or did you have to in order, for the larger trihub to fit.
viper strike
- Dec 22, 2016
- belle plaine mn
You can also carefully remove dust/water seals on those new bearings and pack em full of a good synthetic grease. Not much in there. Your bearings will last twice as long. Just be very careful removing the dust/water seals.No studs and changed bearings each begainning of winter, no issue for me with the trihub since 3 years
rbell14
Those who have questions about moving away from the tri-hub take a look at this thread... EPIC failures on stock Tri-Hub.
Once it goes, you are stranded and it doesn't tow very well as the track tension becomes very lose. I was lucky and pretty close to a parking lot. Regardless if you like 4 wheels or 2 wheels JT and others have solutions that provide isolation with each wheel instead of of tri-hub that fails if one bearing fails.
Plenty of pics!!
https://ty4stroke.com/threads/tri-hub-failure.140929/
http://www.jtatv.com/STEALTH_BIG_WHEEL_KIT_p/stealth big wheel kit.htm
Plenty of pics!!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
If you don't have oversized wheels, you can completely remove the block's and shaft for even more transfer.I like how you removed the black stop blocks, you ride like this in stock configuration
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
On the transfer blocks, entire rod is now removed as I ride more off-trail than on.I like how you removed the black stop blocks, you ride like this in stock configuration
On the Tri-hub replacement, I ordered the axle from OFT and the wheels separately. They are stock size so I can run without the rear cross rod in the skid.
- 44K
