black john
o/d
most affter market set up all ready come with a lttle more o/d than stk. i think the way you explaned about the roller set it sounds simler to a A/C clutch. if that,s what it looks like there could be a shalow cut out on the helx where roller plate could fit into at max shift out if so that your o/d. those are a nice set up. fyi did you know that the cat and yamaha secoundery,s are so close to the same it,s scary. the cat roller plate even fits on to the studs that hold the helx on the yamaha clutch. i was thinking a year or so back about moding a cat helx and drilling and taping three mounting holes and bolting on a A/C roller cover my self.
SharkAttak
i know the washer is a 5/16, but how thick should it be?
black john
washers
lock washers work the best and they are over 1 mm. this all so gives the secoundery spring a little more room in the clutch before the sping coil bind,s.
SharkAttak
Re: washers
i have an ulmer stage 2 clutch kit installed in my attak, so this mod. wouldn't doing anything, would it?
black john said:lock washers work the best and they are over 1 mm. this all so gives the secoundery spring a little more room in the clutch before the sping coil bind,s.
suburban
No, nothing. the washers is the cheating way to acomplish the helix mod.
black john
washers
with the affter market helx,s there si no advantage unless you have the primary shaved for o/d your there. these washers do three things 1 moves the center boss out. 2 moves the tip,s away from the clutch so they dont touch. (even with the boss cut down) 3 gives the stk sping a little more room to compress with out haveing coil bind. and it,s very cost efftive and it,s not perment.
SharkAttak
Re: washers
wonder if it would work on the phazer fx? i have an ulmer clutch kit but it only consist of the primary spring and the weight, the helix is stock
black john said:with the affter market helx,s there si no advantage unless you have the primary shaved for o/d your there. these washers do three things 1 moves the center boss out. 2 moves the tip,s away from the clutch so they dont touch. (even with the boss cut down) 3 gives the stk sping a little more room to compress with out haveing coil bind. and it,s very cost efftive and it,s not perment.![]()
does this mod give you more rpm on top
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Will not work on a Phazer as it is a completely different secondary design.
sorry,i forgot to mention that its for my 04 warrior
Jabber
- Dec 24, 2005
- Penticton B.C.
- 2017 Sidewinder mtn 162
What would this mod do for a mountain rx1? Would there be any increase in track speed in the deep powder?
black john
washers
it would depend were you run in your clutch,s. this manly help.s when you are runing into the top of the clutch. to make use of a little bit of o/d that,s in the stk primary. if you get your primary cut for more o/d you would need a lot more than this alone would give. as the stk spring would need about 7-8 mm more room after moding the primary and secoundary for o/d. as i have never rode in the mtn,s i can not give a fair opinon on mtn rideing . as we here on the flat lake rideing run at fairly high speed,s reg basis (100+mph) over long run,s (20-30 miles)
mtn
I do think you will see any gains mtn riding.
Jabber
- Dec 24, 2005
- Penticton B.C.
I have just changed my secondary sping and will ride with no other changes on Sunday. Monday I will add the washers and post difference after the ride.
