Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Trying to evaluate the need for a aftermarket lower belt guard on stock Sidewinders to lets say max 240hp tunes. As I understand most bigger tunes runs higher risk.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Cheap plastic on these sleds compaired to the japan sleds. You need a protector.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I think its cheap insurance. You might not have a "belt blower" but at some point you're probably going to pop a belt and they usually cause carnage.
justinator
No sense it chancing it. Ive only blown 2 in 4500 miles. First one was light acceleration at 75mph and it broke my lower side panel up near the shock mount. Installed precision guard after. Blew second belt around 4000 miles and didnt even leave a ding in the guard. Wouldnt even run a stock winder without one.
Has anyone considered using a belt temp gauge system? Buddy is putting one on his side x side. He says it reads the belt temp at all times.
If works as good as he mentions then you could stop before the belt blows.
sideshowBob
I have had a belt temp gage on my SW for two full seasons now.
Here's a link to some posts
https://ty4stroke.com/threads/belt-temp-gauge.161463/
sideshowBob
justinator
Ive had belt temp gauge for 2 seasons as well. It will save a belt if the failure is due to heat but belts blow for other reasons. My second and last belt that blew was operating at 115 degrees when it came apart. It was likely defective as I replaced it and finished the season without another issue.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Ran 240/270/300 this winter for 6500km. I use the xs825 belt and change it every 2500 ish km. Seems like alot of guys start having alignment issues after blowing belts, so I'd rather just change it out ahead of time.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Things have improved ALOT on belt blowing since 2017! Just getting the offset where it needs to be is huge.. Change belts every season and get your clutching right..
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
You damn Celsius guys!!! Lol
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
You mean the rest of the world.You damn Celsius guys!!! Lol
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes just do it.
BOP works well, have had mine off a couple of times to straighten after blowing a belt!
No blown belts this year, thanks to clutch offset and XS825 belt, and short season of only 1600 miles!
sideshowBob
LOL
That is Fahrenheit on the gage...cood morning, looks like 15'f sled had not been run yet.
SideHogger
- Apr 16, 2016
- upstate ny
Yes.....we’ve been converting over since I was in grade school!You mean the rest of the world.
