Grunt
- Nov 21, 2021
- Forest Grove BC
- 2016 Viper MTX
Thanks for the tip. Will check them out later this weekCanadian tire sells Mobile 1oil filters, M1 108 is the one that works on Yamaha 4 strokes. That’s what I use.
Jim R
- Aug 30, 2015
- Rockford MI
- SR Viper / Procross
I use Wix 51358 filter and any Euro Spec 0-40 Syn Oil Amsoil or Mobile doesn't really matter.
Rock Auto for filters about 7.50 each and 3.5 qts oil.
Gear lube 90-140 Amsoil from a 5 gal bucket. Not sure how much due to using a pump.
Change every year regardless of miles. Its cheap insurance.
ryan11007
- Feb 3, 2014
Great info thanks. Just need to see what to get for chain case lubI ordered the filter from fortnine but you can use this to match filter…I use synthetic 75w90 gear oil for chain case.
https://www.oilfilter-crossreference.com/convert/AC-Delco/PF1127
ryan11007
- Feb 3, 2014
Thanks ill c where i can get some gear oil. Ill try rock auto next time. Hopping the euro motormaster oil 0w 40 will be ok. Just dont know what to look for. To make sure additives so on dont bother the components. Only grabbed it cause it was on sale.I use Wix 51358 filter and any Euro Spec 0-40 Syn Oil Amsoil or Mobile doesn't really matter.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Rotella T6 full synthetic or Mobile One 0-40. My dealer straight up told me that those are great choices.
What you need to remember is that the manufacturers do not make there own oil or fluids. Case in point: I have a few Polaris quads with the Hillard front differentials. The dealer insists that you use their $20/liter Demand Drive fluid. Spent a few moments on the Hilliard Corporation website and they recommend UTF (Universal Transmission Fluid) which sells for $12/ 4 liters. If the guys that make the parts for Polaris and the US government recommend it, good enough for me. No issues in 10 years and at about an 7th the price
ryan11007
- Feb 3, 2014
Thanks good point. Works for me. What do you use for gear or chaincase oil? A few guys on this tread meantioned a few. But only 2 guys use the same weight. Seems 2 be a wide range. Go with best bang for my buck?Rotella T6 full synthetic or Mobile One 0-40. My dealer straight up told me that those are great choices.
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
Looking to see if any one has bought other then yamaha products for oils and filter? If so please include type of oil and part numbers. Also looking for chaincase oil. How do u match filters?
Located in northern ontario canada
