heath@mpi
- Aug 20, 2008
heath@mpi
- Aug 20, 2008
Mac again, just one more note. The GEMS shoule be on its own line. I guess the fuel reg is OK there. But here's the biggie. We need to know the boost the GEMS is seeing, not the throttle body. Please connect the Boost gauge to the Air Box. The Valve is correctly connected to the throuule bodies. I suspect that the GEMS is seeing a lot more than 2 psi. The 2 places for measuing boost are quite similar, but very different at part throttle. This again make me think that the Blue-Green is too low and Red is too high. Also maybe Blue-red is too low.
Thanks,
Mac
Thanks,
Mac
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Awesome reply Mac , Thanks.
I know the Gems can work , my MPI sc Apex was awesome for 2 years.
I have been talking to Heath about the mid lean, many times, knowing it would break the motor , tried all his ideas since Dec 20 , when I first rode the sled. Now it has 1450 km and dripping oil out the breather. Pulling it apart Tues nite.
I have been riding , but trying to stay out of the 14-16s. best we can.
The sled has your bypass valve , and it is plumbed the way you want it , with the exception of the boost gauge, I will change it.
The sled will cruise in 13.0-13.8 at lower vacuum / boost , but as it approaches 2.0 lbs up goes the afr.
Thanks again , good to see the Boss is involved.
Please give me new Gems settings to start with.
Thanks , Glen .
Thanks , Glen .
gsxr
- Feb 24, 2006
- 2023 SRX
********* WOW *************
CUSTOMER SERVICE ROYAL !!!!
I just recieved a new reprogramed Gems !!!
Thanks Mac , Heath , will test and advise !!!!!
gsxr
- Feb 24, 2006
- 2023 SRX
ttt
when is the nytro motor rebuild party happening?
Glad to hear Mac and Heath are stepping up to help out...that is QUICK turn around time..kudos to MPI.
heath@mpi
- Aug 20, 2008
Glen give me a call today sometime in later afternoon if you can.
Matt i will call you little later.
Glad you got the box i want to run you through some settings.
Thanks again.
Dont hesitate to call! Anyone
Thanks again.
xtxnytro
MattZx6 said:when is the nytro motor rebuild party happening?
Party has been in my garage the past 2 nights, make sure you drink lots before you start your tear down, its not going to look good.
i'll drop my motor by your place next week ...you will be a seasoned vet by then!
xtxnytro
MattZx6 said:i'll drop my motor by your place next week ...you will be a seasoned vet by then!
We'll have to do it in your garage so we have some snow to try it out in afterwards.
gsxr
- Feb 24, 2006
- 2023 SRX
I have lots of snow , do it up here ! and 22 miles of lake to try it on.
Plus I have the new box !! and cold beer.
that 22 miles of lake is what did my motor in!
or the 60+ miles of lakes a few weeks ago, bu we had to stop frequently for arctic cat x fires blowing belts, if you need help let me know
gsxr
- Feb 24, 2006
- 2023 SRX
The new controller is the fix , can add lots of fuel anywhere , just have to dial it in to get the fuel milage back.
Motors are being built . Testing to resume , will have some flat land numbers for milage soon.
For now , (new controller ) 12.5 afr all the way , then 11.8 wot
1 green
2 yellow
3 red
3 boost added
2 accel pump
6 altitude
1 green
2 yellow
3 red
3 boost added
2 accel pump
6 altitude
