richyrich
What is everyone doing, or should I be doing when running a Water Meth injection kit, when the riding season is over. Im not running a great deal, 2 / 90ml nozzles, but some is enough.
EW
EW
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Nothing. If you run alcohol and water nothing is needed. Water and alco will mix perfectly and will not degrade. If you run windscreen wash fluids I would drain it and run water thru the system to clean it. I run a mix of isopropanol (2propyl) and water. Pre-season I always do a function test of the system by adding 12 volts to the pump, it will pump at full pressure and blow away any impurities. If the system blocks my failsafe system will drop my boost t0 a safe level.
