rxwhopper
I bought a tuner off a former sidewinder over and he assumed that could use tuner on both td and hurricane. i mainly bought to add launch control to my hurricane tune. i may sell outright but would prefer to trade.i have cluster flash. This thing will read and switch tunes but wont load any programs from dave as its locked to td
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Maybe see if gap will help you ?? They might be able to unlock reset??I bought a tuner off a former sidewinder over and he assumed that could use tuner on both td and hurricane. i mainly bought to add launch control to my hurricane tune. i may sell outright but would prefer to trade.i have cluster flash. This thing will read and switch tunes but wont load any programs from dave as its locked to td
rxwhopper
i doubt they would want to step on there customers toes with that, i sure wouldnt.Maybe see if gap will help you ?? They might be able to unlock reset??
The tunes are also tied to the vin so if the vin doesn’t match the flasher it won’t work.
rxwhopper
you can add other tunes into it as dealers have a few serial numbers attached to same flasher. This one hooked to my sled reads the flashes, changes the flashes an it also reads all parameters.there has to be someone who had a hurricane flash that wants to switch to td,i had dealer flash mine is only reason i bought this. guy bought it from knew i had a hurricane tune and failed to tell me he had a td flasher.The tunes are also tied to the vin so if the vin doesn’t match the flasher it won’t work.
- 8K
- 7K
