snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I am in the process of taking my 07 phazer all apart and I heard this part hit the floor, I have no idea what it is or where it goes. Anyone ever see this before? Any help would be great, THANKS
I am stumped. What were you working on when it hit floor?
snopro442
- Dec 10, 2007
- neenah wi.
I have the whole sled taken apart to do the stator and give it a good check over, when I took the rag that was covering the stator area off I heard it hit the floor. Not sure where or what it came.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Its from the steering block. It goes over the protruding bolt ends. If you remove the headlight cover you should see it. I would post a pic but the sled is in the shed for the summer.
snopro442
- Dec 10, 2007
- neenah wi.
so what does this little part do?
Cubby
- Dec 14, 2009
Just protects the wiring harness from the sharp bolt threads. I siliconed mine on when I installed the OFT steering block.
snopro442
- Dec 10, 2007
- neenah wi.
This little pin goes inside the throttle block to keep the block from moving, it goes against the bars when you tighten the block.
