yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Have my primary clutch in for replacement (warranty)
Thinking of selling the new oem team clutch and buying a tapp!!
Anyone running a tapp paired with the team clutch?
What's your opinion?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Marc you just can’t stop, or can you
lol..
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I told you it becomes a addiction..lolMarc you just can’t stop, or can youlol..
You will see after your first ride you will be be hooked too
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I'm sure you can get it to work fine. If you want a cheaper route, maybe switch to Yamaha clutches. I have a killer setup for the 129s that gets better belt life than a stock apex.
Fleecer
- Jun 13, 2014
- 2019 SRX
Please share??
Turboflash
- Mar 18, 2019
- Southern MN
That cracking is all too common with Team clutches. It's caused by rapid heat buildup at low belt engagement (heat checking). It's also potentially very dangerous because eventually the primary will fly apart. I have documented cases of injury due to primary fragmentation and explosion. It's a design defect - clutch is too thin down there. There is a class-action lawsuit going against Arctic Cat on this. I've attached the Arctic Cat recall on this issue. If you bring your cracked clutch to your dealer with a copy of this, they should replace it. Unfortunately, they will replace it with another Team clutch that will eventually crack. I heard recently that there is a new version of this Team clutch that supposedly has had this defect addressed. One thing you can do to help prevent this heat cracking is to think about keeping the sled moving (don't stop allot). The heat comes from belt engagement so the less you stop and start, the less heat there is in the clutch face.Have my primary clutch in for replacement (warranty)
Without modifications, I don't think you'd be able to use a stock Team secondary with a Tapp primary. Your Team secondary has "auto-adjust" for belt height. Belt tension at idle is pretty high because the matching Team primaries have a center roller bearing so at idle the bearing just spins as the engine turns. I think if you tried to use a Team secondary with a Tapp, the belt tension would be so high at idle there would be a ton of heat and it would literally pull the engine idle speed down. Remember the stock Team secondary is a compression style clutch.
I think to make it work, you'd have to play around with longer belts and/or do a torsion conversion on the secondary.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Just set deflection with team secondary like any other sled, spacers
Turboflash
- Mar 18, 2019
- Southern MN
Yes.
Nortrider
- Oct 27, 2019
- Fort kent Maine
- 2020 srx
LolPlease share??
Nortrider
- Oct 27, 2019
- Fort kent Maine
- 2020 srx
Look at that fleecer it says I'm a newbie!
- 10K
- 42K
