Lasse Sjodin
Hello.
Apex XTX 2011
Removed secondary clutch for inspection and cleaning when I see damage to each plate. The damage is barely 0.5mm deep at the deepest point. The damage must have been there during the short time I owned the snowmobile and it has worked as well as possible. What do you think? Can I continue to drive with the damage or do
I just have to buy a new clutch?
![20240228_150852.jpg 20240228_150852.jpg](https://ty4stroke.com/data/attachments/133/133459-6611377d6abc40f5395edbb282a3414e.jpg)
![20240228_150901.jpg 20240228_150901.jpg](https://ty4stroke.com/data/attachments/133/133460-1cba15e57ea3c383e1fef2dce49ce842.jpg)
Apex XTX 2011
![](/styles/vip.gif)
Just be sure that none of those scars are protruding above the sheave surface and drive on.
RobX-1
- Coldwater, OH
If it were mine, I would replace the secondary sheaves but instead of purchasing new, I would contact Travis of Barn of Parts to see if he has any good used ones where you can use your existing spring and helix.
![](/styles/TYLifeMember.gif)
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Clean with a scotch brite pad and ride on!
Lasse Sjodin
OK, thanks for your answers ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
