rustinpeace
seen some past threads on this but the but dont see them for sale. not concerned about just changing it but something that holds it open while removing belt debri if it blows. barn of parts has something for 100 bucks but was wondering if theres another option that is cheaper or if its even needed? i thought once you open it up it kinda locks in place. first season w this one so
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I would Highly recommend getting one. It is possible to get the belt on and off without one, but if you blow a belt and have to dig the Reminence of your belt out of your clutch, that tool is priceless.seen some past threads on this but the but dont see them for sale. not concerned about just changing it but something that holds it open while removing belt debri if it blows. barn of parts has something for 100 bucks but was wondering if theres another option that is cheaper or if its even needed? i thought once you open it up it kinda locks in place. first season w this one so
I have one on both my Sidewinders and my Apex.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
If I'm working in the garage, I just use a long ratchet with a 12mm socket on 1 of the nuts and turn the secondary clutch CW, (with the brake locked) then push to compress the spring and open the sheaves. Doesn't cost anything.
Maybe not the most practical strategy when on the trail however.
rustinpeace
https://www.ebay.com/i/153763172673...5Np9COL12vMTFuYIKIxLUJnhlgOUpUNxoCYNcQAvD_BwE
found this also. looks like an adaption of the skidoo version
rustinpeace
thanks yea one of the links on that post is a place thats 20min from my home. same one i found on ebay but closer and cheaper. 38 bucks and made w a machine so balance should be good
- 148K
- 37K
