fisrt off what is the helix in the stage 2 for a 06 rtx? i want to know what im working with.
also what are you guys running for weights in your supertips? i had to take all weight out and even grind down the bottom of the tip to get the correct revs.
The standard Apex RTX helix is stamped a "G" if you are running a 2" x 136" track our setups will not apply because we have not done any testing with that combination. It will take much lighter weights or a much shallower helix to make it work correctly.
