I was changing my ATV oil over the weekend and I was really happy with these kits. On the back of the box it tells you the models that are covered and the amount of oil needed to complete the job. Each kit included 3 quarts of oil, filter and plug washers, and gaskets that will cover a wide verity of machines.
The kits are also available for Sleds with Semi Synthetic and Full Synthetic blends. All following the same packing as the ATVs with oil, filter and washers needed to replace drain plug washers.
Ganz
How much was the kit?
I change my oil really often so I run the semi synth.
