Fast
- Sep 25, 2018
Tried that spring in stock srx and it would pull 8700 then drop to 8500 and down 10 mph on ice good conditions it had great backshift but I i would of had to bump the primary up to run it, that was at 6-2 when running it at 6-3 the clutches were burning hot never tried it w/o, with the stock pink at 6-3 got more top end and cool clutchesSorry to hijack. Is this the part number for the V2 Dalton spring?
And is that a good choice for a stock winder?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Does this spring bind @ 6/3? Those coils are awful close on that stocker, and would think without machining the spring pocket on the secondary it would bind @ 6/3with the stock pink at 6-3 got more top end and cool clutches
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Understood, thanks for sharing. Ultimately I'm going to tune it and thought this spring would work well stock & for tune.Tried that spring in stock srx and it would pull 8700 then drop to 8500 and down 10 mph on ice good conditions it had great backshift but I i would of had to bump the primary up to run it, that was at 6-2 when running it at 6-3 the clutches were burning hot never tried it w/o, with the stock pink at 6-3 got more top end and cool clutches
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
IT WILL !!!!thought this spring would work well stock & for tune.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
At 6-3 that Pink is binding HARD at the top end.
Even the stock Yellow can not go over 3-3 and it will bind.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
I run a TD PowerTrail 275hp tune (CAI & 3" exhaust) and I am running the TP Orange secondary spring at 3/1 with no slipping. I also have 192 1.45 studs in the scooped double Stud Boy Super-lite Pro backers. I have pretty good hookup on snow with those.Mike can chime in and tell you the difference .. If I remember correctly the TP orange has SLIGHTLY more pressure then the B/O Dalton.. Both being at 6/3. I would say running either of these springs less then 6/2 on 270 tunes will burn the belt through the secondary. I have both springs and they both are great choices IMO.. A lot of factors involved, including traction being a big factor .. If you got lots of studs and a good pattern you better have the secondary spring wrapped up 6/3. Gears would be another factor. etc. Hey when you squeeze the lemon don't whack it right to the bar, just a nice even pull to the bar.. I find this to be a better way for hook and possibly lower belt temps?
If you want to truly find out what's best start at 6/1 and temp check your clutches and belt.. Too hot? /black marks? in secondary go to 6/2 and check again. Keep twisting until you find the twist that keeps belt temps low and clutches clean. I did this and found 6/3 on the TP orange to be best for temps. On the 22 (TD MAX 17)I changed my helix from a straight 45 to a straight 38, and still in the process of temp checking and twisting.. Im at 6/2 now with TP orange. I run 200 + studs and it hooks hard on hard pack.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
What helix? What length track/ lug? studded outside the windows? Gears? Primary weights and total weight? These things are major factors. Temps( heat gun) after 1/2 mile pull?I run a TD PowerTrail 275hp tune (CAI & 3" exhaust) and I am running the TP Orange secondary spring at 3/1 with no slipping. I also have 192 1.45 studs in the scooped double Stud Boy Super-lite Pro backers. I have pretty good hookup on snow with those.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
17 LTX SE with 137 x 1.25" trackWhat helix? What length track/ lug? studded outside the windows? Gears? Primary weights and total weight? These things are major factors. Temps( heat gun) after 1/2 mile pull?
Not studded on the outside (192 down the middle)
33/35 helix
Stock 21/41 gears
TP Heavy Hitters at 76.3 grams
57.5mm clutch offset
Clutches are both just warm but not hot
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Wow that’s a ton of weight for hitters! That helix angle must be helping to hold that belt. Thanks for details. I can’t run anymore then 68 grams on hitters with a straight 45 OR Straight 38. Anything more then 68 grams and I can’t pull Enough RPM up top end. I like 8900-9000 up top. Nothing less.17 LTX SE with 137 x 1.25" track
33/35 helix
Stock 21/41 gears
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
TD max 17 tune.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
The extra weight is because I am running a 2012 Vector primary clutch. I was at 71.4 grams with the Sidewinder primary. I am running 8950-9100 up top depending on conditions.Wow that’s a ton of weight for hitters! That helix angle must be helping to hold that belt. Thanks for details. I can’t run anymore then 68 grams on hitters with a straight 45 OR Straight 38. Anything more then 68 grams and I can’t pull Enough RPM up top end. I like 8900-9000 up top. Nothing less.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Okay that changes things. That’s a ton of weight on hitters. What tune with 71.4 grams? What rpm that run with winder clutch.The extra weight is because I am running a 2012 Vector primary clutch. I was at 71.4 grams with the Sidewinder primary. I am running 8950-9100 up top depending on conditions.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
I just posted that because not everyone has the issue of needing to run the TP Orange secondary spring at a high amount of wrap like you do. Thunder Products recommended 3/1 to me and it has been working well.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
Same as what I posted above for the tune and same RPMs with the Sidewinder primary and 71.4 grams.Okay that changes things. That’s a ton of weight on hitters. What tune with 71.4 grams? What rpm that run with winder clutch.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hard to imagine a 35 helix allows for 3 more grams of weight. these secondary’s seem to be very forgiving with helix angle and spring pressure. No way I could run that light on secondary spring without smoking belts. Not sure what the “X” factor is here with clutching o these things but tons of different recipes that work.
