A split sleeve? Otherwise how does a sleeve go over the splines?I just had my axle bearing surface machined & a sleeve made to fit the shaft & bearing.
Brent68
- Apr 7, 2018
- Hayward
- Sidewinder
orange whistler
That puts some concern to me. Time will tell. Running a 285 hp tune with studded track.Careful with the light weight shaft
Dr. FeeLGooD
My Nytro has my back for when the Sidewinder is not cooperating.never mind just found the other thread. Glad I didn't sell my Grand Touring 1200 Doo. At least I have something to ride.
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
is that the black diamond shaft?
It looks to be the shaft used in the Cat Mountain sleds. Jackshaft is hollow and Driveshaft is Aluminum just like that.is that the black diamond shaft?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
BDX shaft are JUNK and strong enough for tomatoes plants...Careful with the light weight shaft
yours look even more solid inside
There are some speed shops that don't do their homework and like to lie at their customers
You must have been the first one!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
That sucks bro
Brent68
- Apr 7, 2018
- Hayward
- Sidewinder
It’s all good, I do all my own work. I knew it had a risk. Was told some high hp sleds were using it with success. The sled is turned up on a 116 octane tune (over 30 psi). Worked fine until I pushed it to 400 hp. Sure made a mess when it let loose. Luckily I’ll have all the parts tomorrow.BDX shaft are JUNK and strong enough for tomatoes plants...yours look even more solid inside
There are some speed shops that don't do their homework and like to lie at their customersYou must have been the first one!
RAMSOMAIR
I'm so glad I bought you original one Brent. Had to use in my daughter's Viper.
Brent68
- Apr 7, 2018
- Hayward
- Sidewinder
Can I have it back ? Just kidding.I'm so glad I bought you original one Brent. Had to use in my daughter's Viper.
RAMSOMAIR
Haha, I bought a new one for the SW and used the one from you in kids sled. Glad I ordered it early!
swrtxlr
- Jun 29, 2016
- grantsburg
- 17 sidewinder rtx le
07 apex gt
00 srx olins
99 mountain max fully modded
gp 292
mod 292
Well since the new axles are on back order and I didn't have time to remove, weld, and turn my axle in between trips. I came up with a fix. I had some shim stock available at industrial supply store. I measured the new bearing and worn shaft. There was .018 difference I cut the .008 shim stock to fit in the bearing put it back together and used the BOP wedge. 1200 miles later it still looks good.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
amen, my 25000 mi nytro towed my 5000mi winder the other day. popped out of gear, right on scheduleMy Nytro has my back for when the Sidewinder is not cooperating.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Wow!
they know the severity of this major problem since awhile .
The drive shaft are BO for the season? Really!?!? Total![]()
They're all back ordered. Probably cause they're waiting for another boat load of quality junk from China.
