SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Unfortunately, the only way to repair this is to pull the engine. On the plus side, you don't have to break it down much to replace the o-ring. I'd pull the oil pan off, then tug the water pump off. Pretty sure you know this already, but there is a gear on the spline shaft of the water pump that you need to hold in place while the pump is being re-installed. put some oil on the o-ring and mating surface of the pump then slide it in, re-install oil pan, and you're good to go. Kind of like this:
LOL! Didn't expect that...funny!!
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
That number works at partzilla.com.
And it's in stock....
https://www.partzilla.com/search?q=93210-386A6
thanks i never ordered from them before. Ill check it out!
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
I order from them a lot and never had any problems. Prices are almost always cheaper than the rest for me. Shipping is on the lower side to unless your only ordering 2 screws or something like that.thanks i never ordered from them before. Ill check it out!
kinger
- Jan 17, 2005
- Clear Lake, IA
I just ordered and yes very good pricing! thanks for the link!
kinger
- Jan 17, 2005
- Clear Lake, IA
They just refunded me, that part number not active!?
it says in stock here https://www.megazip.net/zapchasti-dlya/yamaha/o-ring-22f-932103851600?q=93210-38516-00 and it gives a couple of motorcycle models it fits as well. might end up going to a heavy truck/equipment engine rebuilder with your sample and get one from them.
kinger
- Jan 17, 2005
- Clear Lake, IA
Nope same thing. Go to order and it says may not be available. Dang.
I have found the heavy equipment shops like Cat ect are an excellent source for O rings of all sizes...trouble is usually the price is such that they must think they are made of some kind of Gold/Rubber alloy!
There are O ring kits out there that you cut the rubber of the diameter you need and glue it together to make an O ring you need.
i would go with the cat ones as they are better materials and hold up to temps and pressures that the standard o rings do not. have had an application at work that the cat o ring would work for years and the standard one would only make days.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Have you called and talked to Kevin at Port? He is the man when it comes to Yami parts
kinger
- Jan 17, 2005
- Clear Lake, IA
Yup I talked to Kevin and he confirmed it is discontinued. He was nice enough to do a look up and gave me a list of dealers that had one in stock. One is the same dealer my sidewinder is at right now! I have a call into them now, if they had it I would be extremely lucky it seems!
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
What part is discontinued ? The "O" ring for water pump to case ?
I just bought one 1 month ago came from Yamaha Canada in Toronto. IS was a good # then
kinger
- Jan 17, 2005
- Clear Lake, IA
Yes the o ring is discontinued. Small victory one of the 5 dealers in the country that had it is my local one. I’m going there tomorrow.
kinger
- Jan 17, 2005
- Clear Lake, IA
In deep now!!
