jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
As I sift through the internet for info about my sled, I see there are several different models of the fx nitro. What's the difference between them all? Mine is a 12 xtx - my understanding is that things were changed from year to year as well, like in '13 they upgraded to a 1.25" track. Does this make it a hassle to get parts?
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Well, after some 'smarter' searching I have answers. Looks like the xtx was a good score.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Nope a lot of it is identical they just updated few odds and ends. Biggest change was in 2010 when they went with diff tunnel design to allow more clearance for running boards on the snow and 09 they changed up front suspension a bit for little more stable sled.
Rtx is short track
Xtx is 144" track
Mtx is the mountain sled 162" track I think not positive
Only true differance between any of models within the same track length is just the shock pkg and graphics.
Rtx is short track
Xtx is 144" track
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
I agree but MTX there are 153 and 162 optionsNope a lot of it is identical they just updated few odds and ends. Biggest change was in 2010 when they went with diff tunnel design to allow more clearance for running boards on the snow and 09 they changed up front suspension a bit for little more stable sled.
Rtx is short track
Xtx is 144" track
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Nice catch. Not mtn guy so wasn't sure was those came in
THEROOKIE
2009 XTX and 2009 RTX Se had the new tunnel design first. Steeper and more narrow running board.
GYTR GEARHEAD
your 2012 xtx skid is equip with a tip rail to help fight darting on hard pack and 1.25" x 144" in 2012 they fix the hand warmer issue the 2103 came with 1.75" x 144" to switch track all you need to do is to remove the tunnel protector they share sprocket pitch 2.52 and you should consider getting ice scratcher if you decide to go with taller lug not only to extend the life of the hyfax but for cooling issue as wellAs I sift through the internet for info about my sled, I see there are several different models of the fx nitro. What's the difference between them all? Mine is a 12 xtx - my understanding is that things were changed from year to year as well, like in '13 they upgraded to a 1.25" track. Does this make it a hassle to get parts?
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Nice, thanks for the info y'all and very informative "Gearhead". I'd thought about that taller track - missed it by 1 year. I do plan to put a set of scratchers on there for sure, and possibly a skid plate. First we just need to get some snow happening.
GYTR GEARHEAD
the skid is a good insurance to protect that expensive motor for 20$ you can make your ownNice, thanks for the info y'all and very informative "Gearhead". I'd thought about that taller track - missed it by 1 year. I do plan to put a set of scratchers on there for sure, and possibly a skid plate. First we just need to get some snow happening.
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
Does this mean I could simply pull off the OEM plate and make one out of aluminum sheeting or checker plate? The above photo is proof of such? This is getting exciting!
jamieren
- Oct 25, 2015
- Alberta
- 2012 Nytro XTX
2010 Nytro MTX
I have a glass shop where we use lexan (similar to plexiglass but tougher). Maybe that would be good material...
GYTR GEARHEAD
i made it out of 1/8 air craft grade alluminium simply trace out the plastic cover et voila !
GYTR GEARHEAD
to my experience lexan does not do well in cold weather
GYTR GEARHEAD
SnoBird888
Are you still using the push clips to hold the aluminum plate up? I noticed you got rid of the top front one....
- 149K
