snowdust
Is there an option for a larger CCA battery that fits our sidewinders? Sled started good this weekend in -11 temps but I like the confidence in the larger CCA battery I have in the Apex. I know about the EarthX but not willing to pay that much. Anything else?
swampcat
Yuasa GYZ20H, not much more, but supposed to be a better battery.
I just installed the earthX ETZ 14C. Wow what am major difference. So much lighter and smaller, also the voltage seems to be higher as its reporting 14.7 volts on the dash. These things are really nice
Mototown
I think my stock battery is on the way out , it's only 12.2-12.3 volts without engine running. It should be high 12s
Mototown
Is that without engine running, because mine is 14.7 with it runningI just installed the earthX ETZ 14C. Wow what am major difference. So much lighter and smaller, also the voltage seems to be higher as its reporting 14.7 volts on the dash. These things are really nice
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
IntriguedI just installed the earthX ETZ 14C. Wow what am major difference. So much lighter and smaller, also the voltage seems to be higher as its reporting 14.7 volts on the dash. These things are really nice
The average with engine running is 14.7, and it goes up to 14.9. When off its at 13.2
Mototown
If you get that reading after a couple days sitting without the engine charging the battery, that's a good reading of 13.2 voltsThe average with engine running is 14.7, and it goes up to 14.9. When off its at 13.2
I just installed it this morning so I will have to check and update in a couple days.
330CCA
330CCA
ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
I was considering this one
https://www.azbatterystore.com/ATV-0645-480_Arctic_Cat.html
These Lithium batteries if they work as advertised are really nice, super light and small
Boston RX1
I just looked on their website and they are not cheap, but if they last up to eight years, then overall, they will be cheaper. I tend to purchase new batteries every 2-3. I do not have access to a battery tender all year round.
If you look at the TCO (Total Cost of Ownership) its very good. Along with the additional benefits of weight, CCA, low/high protection its fantastic. Every year I have to replace both my batteries in my boat which is like 400. If this works out well in the sled I am going to get these for everything.
actionjack
- Apr 9, 2005
Do these batteries need some kind of warm up process when it’s extremely cold?
- 12K
