goodday
i have 06 apex rtx i install new belt at the end of the season, but it makes noise at idle speed, does the secondary need to be adjusted for the belt ? goodday
sobfrogg
Yes you will have to readjust your secondary.
On the backside of the secondary there are 3 small bolts with washers. Take the bolts out and remove the thin washers (shims) and reinstall the bolts. That should take care of it.
OH you might want to add your location to your profile. It is a site requirement.
Frogg
Frogg
mr.pitstop
sobfrogg said:Yes you will have to readjust your secondary.
Frogg
X2
goodday
thanks i will try that, also i updated my profile thanks goodday
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
