snowdust
Could you expand on the secondary adjustments needed?Both . Shouldn't matter . Secondary adjustments NEEDED
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Well the rollers are soft and guys are getting flat spots on them. Secondary spring could be binding? IMO the helix could POSSIBLY use a higher finish rate on it.. Adjustments > watch your rollers or replace them with better ones. Watch your springs for rub marksCould you expand on the secondary adjustments needed?
The PRIMARY weights have to flat of a profile. Its been posted gains are being made with aggressive profile(more curve, banana shaped) primary weights . . Daltons, Heavy hitters, Hurricane, Supertips.. These all have similar profiles>>>> curved instead of flat like the stock weights
Is it decent stock? YES . just these things are being seen and you have to realize that these issues are posted by guys that are VERY particular and observant.. With that being said. Some of the above things will cause blown belts IMO.. Especially the secondary issues
**remove the metal washer on the OSP unit which is used for belt removal and store in your tool bag**
SRX Boy
Why are you suggesting removing the washer? Don't think I understand - I maybe wrong but belts don't seem to be breaking because of the static float?**remove the metal washer on the OSP unit which is used for belt removal and store in your tool bag**
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
Or Thunder Products , I like his the bestGet a belt adjuster from either Hurricane or OSP
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
It is his sight,but does not appear to be loading on much for the winders yet,he is real active on FB which I hate,but call him and speak to one on one may be a better choice.Maybe this isn't the correct site but I'm not seeing any belt adjusters.
http://www.hurricaneperformance.ca/product-category/power-sports-performance/
Sent from my iPhone using Tapatalk Pro
big5oviper
- Feb 28, 2005
- chateauguay,qc, Canada
- 2017 sidewinder ltx-le red
He has them because I received mine today. I called him and he said he hasn't put them on site yet but he has them in stockIt is his sight,but does not appear to be loading on much for the winders yet,he is real active on FB which I hate,but call him and speak to one on one may be a better choice.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I just watched the thunder vid again,they install the lg. heavy way bigger than it needs to be, washer once they set up the plug,than they put it back in,so whenever you want to open up your clutch to remove belt you can.Or Thunder Products , I like his the best
Scottyvodka
Are you saying they use the big washer to remove the belt and then take it off? I notice the bolt they screw in to upen the clutch is going to dig the cap out of the secondary without the washer there.I just watched the thunder vid again,they install the lg. heavy way bigger than it needs to be, washer once they set up the plug,than they put it back in,so whenever you want to open up your clutch to remove belt you can.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Which ever one you buy,has a steel washer so you don't gouge up the soft aluminum helix, when pressing on it to open the sheeve,to remove the belt,once done with belt removal,leave the washer in place,no need to remove and have to keep going thru removing center bolt,just remove the allen cap bolt and put that back away.Are you saying they use the big washer to remove the belt and then take it off? I notice the bolt they screw in to upen the clutch is going to dig the cap out of the secondary without the washer there.
Scottyvodka
I have the thunder products tool. They say not to use the washer in the instructions for the sidewinder. Not a big fan of gauging the aluminum, only makes sense to use the washer. Unless I'm missing something?Which ever one you buy,has a steel washer so you don't gouge up the soft aluminum helix, when pressing on it to open the sheeve,to remove the belt,once done with belt removal,leave the washer in place,no need to remove and have to keep going thru removing center bolt,just remove the allen cap bolt and put that back away.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
you can use the washer for belt removal but DO NOT LEAVE IT IN ON THE SIDEWINDER AS BAD THINGS WILL HAPPEN AND HAVE.I have the thunder products tool. They say not to use the washer in the instructions for the sidewinder. Not a big fan of gauging the aluminum, only makes sense to use the washer. Unless I'm missing something?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
This should help clear things up.. Aluminum threads/ steel washer rotating very fast.. open and closing of clutch. I do not like posting these kind of pics BUT guys need a visual of what's happening
Scottyvodka
Ok...thank you!you can use the washer for belt removal but DO NOT LEAVE IT IN ON THE SIDEWINDER AS BAD THINGS WILL HAPPEN AND HAVE.
