Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
See video below. Offset is 60mm. Belt is flush or slightly below secondary. My concern is with how the primary moves the belt over after engagement but before it starts to shift in the secondary. You can really see it at the end of the primary shaft. I believe it's compounded when there's a load. Would this throw off the offset for the entire shift or is this normal? Dalton weights & spring, Dalton b/o 6-1 in secondary. Still chasing hot clutches, dealer is still working on addressing why my clutch is closer to the motor as well. As always, thank you everyone for the help.
