ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yeah the MT guys dont have alot of high speed airflow like we do on trails. I know when we get into our real tight corner to corner riding in some of our tightest areas, we really see underhood temps spiking, Belts surely alot hotter.
Are these similar to my temp gun? You know the temp gun that shoots out a red laser light and can read temps fairly accurately close or from across the room...works well.
Dan
Dan
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
and that sensor looks like it would pick up under hood heat before any belt heat being that far away. Seems odd.
I do like seeing the multi-step thumb and hand heaters on the gauges for '19...like doos have.
Dan
The infrared sensor they are using has a narrow field of view, so it's more accurate. You get less averaging of anything else that may be in the sensor's "view". I can tell you that they work very well, but you have to pay attention to it.
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Any chance a high temp threshold could be programmed in, and then have the gauge temp flash, to better get the drivers attention ?
TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
A warning tone for this, knock, and low oil would be great.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Very interesting Allen, thanks for this info. Its cool to see Cat coming with some tech! Mt guys sure will like this feature.....Wonder how it would work for trail guys?The infrared sensor they are using has a narrow field of view, so it's more accurate. You get less averaging of anything else that may be in the sensor's "view". I can tell you that they work very well, but you have to pay attention to it.
I have not had any heat issues with my belt, mine seem to rip in two(snap) more then anything.
Dan
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I’d like to see a aftermarket one for sale. Or is there?
Crossfire12
- Feb 13, 2017
I found one WR-products.com shows average and high temps on gauge. Has bright light to warn you.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Every one if mine have grenaded into a million pieces. Pretty sure it's an offset issue. Going to get the alignment tool soon.Very interesting Allen, thanks for this info. Its cool to see Cat coming with some tech! Mt guys sure will like this feature.....Wonder how it would work for trail guys?
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I hope so.....I just set mine all up with Hurricane bar, and will be trying some new things. Just posted a bunch of new stuff in my build thread.Every one if mine have grenaded into a million pieces. Pretty sure it's an offset issue. Going to get the alignment tool soon.
Id be happy with 1000 miles on a belt, just dont want to have to baby things...grrr
WinterWolf
- Mar 25, 2017
- Connecticut
According to Dave at hurricane, once you align with his tool...no more issues tuned or not!
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I was getting around 800 miles per belt but not much wide open running last year. I'm sure if I was running more lakes they would not have lasted as long.I hope so.....I just set mine all up with Hurricane bar, and did will be trying some new things. Just posted a bunch of new stuff in my build thread.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Yes heat out west is a big factor. No place for the heat to go when chasing the deep days. I stop lots and let thing cool. Be nice to have some kind of indicator stating things are getting hot.Yeah the MT guys dont have alot of high speed airflow like we do on trails. I know when we get into our real tight corner to corner riding in some of our tightest areas, we really see underhood temps spiking, Belts surely alot hotter.
Dan
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
What model sled is this on?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
LOL....and if that works for me I will be the first to praise it! I want belt life more then anyone!According to Dave at hurricane, once you align with his tool...no more issues tuned or not!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Watch video post #1.What model sled is this on?
