Travis Moore
Travis Moore
Also what pitot jet are you guys running for 10-11 psi?!
Blue shadow
On the cpr Jeff said for every three turns it is 1 psi
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
Every waste gate is a little different than the next. What we have done in the past is to connect a pressure reducing valve to the waste gate actuator and increase pressure until the gate starts to open. I recommend that you check your existing pressure before you make any adjustments. Adjust the waste gate accordingly.
lakercr
Tech Advisor
Be careful with that - the psi the gate cracks at is not the same as final boost pressure.
peteracing
Yes, the exhaust pressure itself helps the controler to open the wastelakercr said:Be careful with that - the psi the gate cracks at is not the same as final boost pressure.
gate so, "static" gate opening press., is always higher...
- 37K
