Bender stage 2...1 turn on WG rod= how many psi?
Travis Moore
New York
I am needing about 2psi more for tomorrow, and am curious how many turns shorter i should try to shorten the rod...also what is the easiest way to access the rod?
Travis
Every waste gate is a little different than the next. What we have done in the past is to connect a pressure reducing valve to the waste gate actuator and increase pressure until the gate starts to open. I recommend that you check your existing pressure before you make any adjustments. Adjust the waste gate accordingly.
lakercr said:
Be careful with that - the psi the gate cracks at is not the same as final boost pressure.
Yes, the exhaust pressure itself helps the controler to open the waste
gate so, "static" gate opening press., is always higher...
