kimcoop1324
I have the pilots on my 18 sidewinder 137 . I feel the dual runner doesn't truly work for me. I have lots of push in corners and etc I know that I am actually only running on single runner until I turn but it feels like the outside carbide does very little. What are others using on their 6.9 pilots? Has anyone tried slim Jim doolys? Are they even possible on these skis thanks for any help or opinions . Mike
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I sell quite a few sets of snow trackers for pilots.
RAMSOMAIR
I had too much push initially with my Pilots then slowly started letting off spring pressure on the center skid shock. Make small adjustments then try again. Takes a bit to get dialed in!
fourload
Yes. I also pulled my limiter up 1 notch. It handles great with 8 inch Woodys executive in the center and standard 4 inch carbide on the outside.I had too much push initially with my Pilots then slowly started letting off spring pressure on the center skid shock. Make small adjustments then try again. Takes a bit to get dialed in!
number1kyster
I have pilots. My straps are pulled up one hole. Center shock spring was all the way loose initially, but the sled was a bear to turn. I just tightened it 1 turn at a time until I found the sweet spot. I'm running 6" in the center and 4" on the outside, but I don't have studs either.
Swampfox
- Feb 25, 2017
- Northern Illinois
- Yamaha Sidewinder
I run 8” bergstrom triple points on my 6.9s. I have a 129” but I have no push. Best setup I’ve used so far.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
ACE carbides by woodys carve nicely....less push then round bar.
6.9 will always have some push in any loose or pow, since its a wider ski. Its meant to float more.
5.7 will carve more in these conditions IMO.
Its a compromise, and if you want true carving in soft you need a c&a or a pilot R type ski, but be ready for heavier effort.
Dan
Dan
- 10K
