Bleeding brakes
Mike Belanger
Age
56
Belle River , Ontario
Canada
2017 LTX-SE Sidewinder
LOCATION
Anyone out there have tricks to bleeding brakes on Winder after having apart? I can't seem to get them done ...
Had the same trouble and i found some info on the viper page that recomended forcing fluid from the bleeder to the master . I finally got fluid down to the caliper but had to pump the cylinder about 300 times
It's frustrating, but keep pumping it will happen. At least you can do it alone. No special tricks.
Turkey baster with plastic tube over bleeder ,squeeze slowly until the upper reservoir is full. Go slow you will see bubbles, once full your good to go , no pump bleed etc.
The liquid flows easily, Simple and works well for me.
I connect the rubber hose to the bleeder, and i pump
I use a similar setup to the turkey baster method now, it’s a vacuum pump bleeder with the hoses reversed so it blows into the catch can that’s filled with brake fluid. It works great, no pumping, it pushes the fluid backwards through the system.
The other way I used to do it was crack the bleeder at the caliper, fill the reservoir and let it gravity bleed until fluid is seeping out the caliper then close the bleeder. Now slowly pump the brake lever, you’ll notice a couple bubbles after every pump come floating up in the reservoir. Keep pumping every 5~6 seconds until the bubbles stop and your done. It does take about 15 minutes of pumping tho.
I’ve tried hooking up to the caliper with my suction bleeder and it really never seems to get all the air out
15 minutes of pumping until the liquid comes out bubble free?
You need to clean your wordage up on this family website before you get thrown off...................................................AGAIN!
Lmao
That dam Ski-Doo ECU Brain of yours is twisting things around..... not my intended meaning dam it!
