Mike Belanger
- Sep 22, 2015
- Belle River , Ontario
- 2017 LTX-SE Sidewinder
Anyone out there have tricks to bleeding brakes on Winder after having apart? I can't seem to get them done ...
dooe
- Sep 13, 2014
- byron center
- 17 sidewinder rtx le
Had the same trouble and i found some info on the viper page that recomended forcing fluid from the bleeder to the master . I finally got fluid down to the caliper but had to pump the cylinder about 300 times
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
It's frustrating, but keep pumping it will happen. At least you can do it alone. No special tricks.
Make sure when you open the bleeder while bleeding it that you open it a lot.Not just 1/2 a turn. Go 2 or more.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Turkey baster with plastic tube over bleeder ,squeeze slowly until the upper reservoir is full. Go slow you will see bubbles, once full your good to go , no pump bleed etc.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I used an oiler and pumped the fluid backwards through the system, and then bled conventionally. Pain in the #*$&@, I could have took the sled apart and put it back together faster than it took me to bleed that.
https://www.acklandsgrainger.com/en...kwcid=AL!3645!3!303439922828!!!g!545542865024!
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
The liquid flows easily, Simple and works well for me.
I connect the rubber hose to the bleeder, and i pump
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I use a similar setup to the turkey baster method now, it’s a vacuum pump bleeder with the hoses reversed so it blows into the catch can that’s filled with brake fluid. It works great, no pumping, it pushes the fluid backwards through the system.
The other way I used to do it was crack the bleeder at the caliper, fill the reservoir and let it gravity bleed until fluid is seeping out the caliper then close the bleeder. Now slowly pump the brake lever, you’ll notice a couple bubbles after every pump come floating up in the reservoir. Keep pumping every 5~6 seconds until the bubbles stop and your done. It does take about 15 minutes of pumping tho.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I’ve tried hooking up to the caliper with my suction bleeder and it really never seems to get all the air out
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
15 minutes of pumping until the liquid comes out bubble free?
You need to clean your wordage up on this family website before you get thrown off...................................................AGAIN!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Lmao
That dam Ski-Doo ECU Brain of yours is twisting things around..... not my intended meaning dam it!
