stopdropanroll
I have blown 2 belts in 2200 miles, each time the top of the belt comes off and is in small pieces below, I am no clutch expert, so do you think my belt is sliping and causing too much heat and delaminating the belt, if so what would be the fix??More clutch wieght??
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
More clutch weight... but it depends. What is your current clutch setup, rpms, gearing, the more details you can deliver the easier it is for the tuners to give you advice.
stopdropanroll
All stock, I didn't want to mess with this thing till this summer when it gets a turbo, RPM's at top end seem to be ok 8700-8900, but I am just asking opinions on what could be the issue, maybe its a bad batch of belts???
ptt
Guest
belt
I bet your center to center is out look in the nytro forum. Airwolf had the same problem, his center to center was out.
- 17K
