jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Wingwong
- Mar 20, 2018
I’ve heard a lot of guys talk about there belts basically breaking. Mine almost did but I caught it. Noticed a vibration. This was after a very long high speed run.
Good catch could have been a lot worse
kimcoop1324
I am curious if you had aligned your clutches prior to this belt problem
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
When I first got my sled my offset was just under 60mm. I put around 1000 miles like that. I then removed my inner washer which put me at 58.6mm. Haven’t aligned with the Hurricane tool but I would still like to.I am curious if you had aligned your clutches prior to this belt problem
DooZ
Tuned? Either way, in my opinion that's good belt life for a 200+ hp machine.I’ve heard a lot of guys talk about there belts basically breaking. Mine almost did but I caught it. Noticed a vibration. This was after a very long high speed run.
kimcoop1324
I aligned mine with hurricane tool but can't get out there for another 2 weeks. Hopefully this tool will make the needed difference.When I first got my sled my offset was just under 60mm. I put around 1000 miles like that. I then removed my inner washer which put me at 58.6mm. Haven’t aligned with the Hurricane tool but I would still like to.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
No tune on that belt. I am tuned now so I’ll see the comparison. I will say that many of miles were cruising miles. I wasn’t easy on my belt but wasn’t doing wide open long pulls. Until now lol.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
2500 miles, DOyou think it was getting WORN ,TIME TO CHECK way earlier like 1000 miles,How many miles do you think you can get with a turbo, ?DID you measure ,check if your belt is worn tTHIN below spec, BELTS on a turbo WEAR, WHY would most everybody brag how long will my belt last before they blow, Must be people on HERE are not used to HORSEPOWER, everybody better go back to the 165 hp APEX! JUST SAYINGI’ve heard a lot of guys talk about there belts basically breaking. Mine almost did but I caught it. Noticed a vibration. This was after a very long high speed run.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
2500 miles, DOyou think it was getting WORN ,TIME TO CHECK way earlier like 1000 miles,How many miles do you think you can get with a turbo, ?DID you measure ,check if your belt is worn tTHIN below spec, BELTS on a turbo WEAR, WHY would most everybody brag how long will my belt last before they blow, Must be people on HERE are not used to HORSEPOWER, everybody better go back to the 165 hp APEX! JUST SAYING[/QUOTE
I changed the title so people don’t think I’m bragging lol. Just sharing information is all.
Crossfire12
- Feb 13, 2017
I’m not ridiculing you, just pointing out with a turbo your belt wears thin, your set up is working great, YOUR NOT A BELT blower, under 1000 you might be! People seem to ride these until their belt blows must be some kinda honor to get the most out of a belt.
eastmark
You’re not mad are you ? Haha
Wingwong
- Mar 20, 2018
Nice to see another thread about belt longevity.
2500 miles on 1 belt is worth talking about on any high performance sled . Keep us informed on your belt life with tube upgrade.
Question: are you studded?
fourload
That is great belt life for a high hp sled. I always change them out around 1000miles.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Which belt? 8jp or 8dn or ?
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
I was not studded on this belt but am now. We’ll see how things go. Cheers.Nice to see another thread about belt longevity.
- 15K
