foolery
- Sep 12, 2015
- Cambridge
- 2016 Phazer.... plus a couple of 2016 Polaris 800's
call it clean....
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Here is a question for you guys. I put the cat rollers in my sled. Also set my secondary up to 6-1. Now I was running r/r grade last weekend and the snow was thin base with semi setup snow but not hard. Now if I would pin the throttle on long stretch the sled would rip to 90 and climb to 98. It seemed like it was falling on its face up top. Now if I would slowly roll into the throttle and eas it up I would run 80 mph at half throttle. Something seemed off to me. Now on hard packed road I could get into the 100s with eas. Would this be the spring binding or just soft snow conditions? I'm on a Rtx Le with 180 studs.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Soft soft snow eats a ton of power on this chassis not sure how it effects the winder. But my viper 15 gps mph slower in the soft stuff vs a hard set up trail.Here is a question for you guys. I put the cat rollers in my sled. Also set my secondary up to 6-1. Now I was running r/r grade last weekend and the snow was thin base with semi setup snow but not hard. Now if I would pin the throttle on long stretch the sled would rip to 90 and climb to 98. It seemed like it was falling on its face up top. Now if I would slowly roll into the throttle and eas it up I would run 80 mph at half throttle. Something seemed off to me. Now on hard packed road I could get into the 100s with eas. Would this be the spring binding or just soft snow conditions? I'm on a Rtx Le with 180 studs.
Sent from my SM-G920W8 using Tapatalk
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Yes that is most likely spring bind.
DC5
Spring binds if wrapped to 6-1
shagman
Vendor
- Feb 18, 2014
It binds at 3-3 also.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
so how do we address the sec spring binding issue?
uprider800
- Mar 18, 2016
- winneconne wi
So should I go back to 3-3?
shagman
Vendor
- Feb 18, 2014
You can add .060 thick washers to the tower bolts before putting helix on. Just make sure the washers done get pinched crooked, sometimes you have to grind a small flat on them. Or better yet get the spring pocket on your secondary machined.
shagman
Vendor
- Feb 18, 2014
I would. For now. We are working on it.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I may have one of the good ones & will check offset & center to center tomorrow. 6-1 for spring & OSP clutch tool. 500 miles, NO dust, never got hot, seeing 9200-9300 rpm's on many runs. I pinned the BEJESUS out of it for 300 of those miles with wide open until the boys climbed inside to hide (mostly to stay warm). 109 on speedo so far. Have AC rollers to put on so will check dimensions & flat spots. Hope i'm not premature, but my signs are good so far...
yamaha06
Damn wish I could of kept the washers I had used on my vipers secondary helix!!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Agreeded,nos-pro hit the nail on the head I think.clean break so to speak? That's pretty much what's happening to the ones that are breaking.. Primary pulls and secondary wont open anymore and =bang. Spring bind in secondary and inconsistent helixes/ maybe even springs causing most it seems
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
1998 MACH-Z
No bind on mine took apart at 500 miles to replace flat rollers couldn't find a spot on the spring where the paint has rubbed. Wrapped at 3-3It binds at 3-3 also.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Steve,109 was allyou got out of it so far? That's not WO in the county lol hell that almost what I hit my tree in back yard at he he,oh I got the results of my leg damage tonight torn ACL torn MCL and broke knee cap,she said she has never seen anyone with such a poor MRI reading to walk standing up,in her office and be able to squat down and have my legs look this good,i said,they were soft trees lol oh I ment my head was soft,for not getting insurance,i also stated,i went on a snowmobile ride last week on my boys same sled I crashed,now I only did 80 miles and only took it to 80,but it was 5pm and plenty dark lol..I may have one of the good ones & will check offset & center to center tomorrow. 6-1 for spring & OSP clutch tool. 500 miles, NO dust, never got hot, seeing 9200-9300 rpm's on many runs. I pinned the BEJESUS out of it for 300 of those miles with wide open until the boys climbed inside to hide (mostly to stay warm). 109 on speedo so far. Have AC rollers to put on so will check dimensions & flat spots. Hope i'm not premature, but my signs are good so far...
- 17K
