Any help on how to measure offset? Where you measuring to get 58.1 to 61.1. I've always just used a straight edge.
Check "Flat spot roller" post. On page 15 Shagman attached pic from Manuel showing how to check offset.
Leaving early tomorrow morning so I took 3 washer, sanded a flat edge to fit in helix and then put them on the surface grinder to make them identical in thickness. I will report how this works as early as tomorrow night. I have the TD turbo force, TD Ecotrail, Dalton weights from TD and 192 - 1.52 INS stingers. I also have my wife's Viper with me if I need to try that secondary.
Viper clutch helix cut may/may not be conducive for optimum performance, but I would be curious in a temp comparison.
Say 2 mile wot winder roller, repeat test with viper button....find cheap harbor freight lazer thermometer and measure heat differences.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
- Apr 14, 2003
- Hessel, Michigan
Both of these clutches if not machined will coil bind....giving you different heat temps. "if" machined for coil bind, you will have lower clutch temps
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
someone on here already did the rear clutch set up swap,he was locked in all stock at 109 and put his viper clutch on and gaines 10 mph more.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
what kind of machining for the primary,the split rings? Why does the primary need help?Both of these clutches if not machined will coil bind....giving you different heat temps. "if" machined for coil bind, you will have lower clutch temps
- Apr 14, 2003
- Hessel, Michigan
No, not primary....
Fleecer talks about the secondaries from the Viper and the Sidewinder
what we dont know pete...is maybe his viper clutch is already machined etc...he is a racer and top mph guy after all..
- Apr 14, 2003
- Hessel, Michigan
Agreed
- Apr 14, 2003
- Hessel, Michigan
K....another member with a blown belt..... No washer behind the secondary
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
there is a washer behind mine...and offset is within specs. Granted only 250 miles on my sled so far...but very little belt dust, clutch temps good...and belt looks mint.
foolery
- Sep 12, 2015
- Cambridge
- 2016 Phazer.... plus a couple of 2016 Polaris 800's
have washer behind secondary, blown belt at 280 miles and 2 rollers with flat spots....
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Did the belt snap in half, like a clean break or Was it frayed?have washer behind secondary, blown belt at 280 miles and 2 rollers with flat spots....
foolery
- Sep 12, 2015
- Cambridge
it was a pull in half... no 100 pieces of exploded crap...
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
clean break so to speak? That's pretty much what's happening to the ones that are breaking.. Primary pulls and secondary wont open anymore and =bang. Spring bind in secondary and inconsistent helixes/ maybe even springs causing most it seemsit was a pull in half... no 100 pieces of exploded crap...
- 17K
