uofm
They found a boost leak. That was the reason only getting 7900 rpms out of it. Now she is running a lot better but I am still short on rpms 8600 to 8750. TD 270 tune stock can with Dalton weights (empty), all stock Yamaha springs. 1.75 137 back country track. Any ideas?
RAMSOMAIR
Not sure about the TD tune but the Hurricane 270 makes 274hp at 8700rpm!
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
which weights? Is it broken in?
might wrap sec spring 10° more.
Fleecer
- Jun 13, 2014
- 2019 SRX
State weights, springs, helix, belt, tune.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Check your primary spring to make sure it’s not broke.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Mine was a little lazy .Check your primary spring to make sure it’s not broke.
Turns out the primary spring was broke in 3 pieces , but still running pretty good !
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm running 72.8 grams on my QAY70 dalton weights on MS16 SM. O-S-O 35/142 primary spring, dalton BO secondary spring and 35 helix.
- 7K
