**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Im not sure if this was correct...but heres what I did...I removed the vacuum line you mentioned and plugged....I took the oem brv and flipped it to lock in the air...then tdc on the motor...after I found the actual leak...I m not sure if the gauge was right..but i got to well over 30 psi which surprised me
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Sounds right to me. I wasn't able to get above 25 psi before the waste gate (I assume) opened and bled pressure.
- Apr 14, 2003
- Hessel, Michigan
I just got the new Blow off valve from EVP. That sucker is nice! Much better than the plastic one.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
How much boost are you going to be running this year?I just got the new Blow off valve from EVP. That sucker is nice! Much better than the plastic one.
- Apr 14, 2003
- Hessel, Michigan
On trail, probably same as last year....but may test the race programs on long straights on trails. But will run more boost on the asphalt.
ShootToThrill
All set with tester, one minor leak taken care of. Whoever needs it next call out #5 and pm where its going. I can send it out monday!
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Glad it worked out for ya!All set with tester, one minor leak taken care of. Whoever needs it next call out #5 and pm where its going. I can send it out monday!
ShootToThrill
I sprayed things down with soapy water, like we used to at the tire shop. Really shows where the leaks are.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Peace of mind is worth $1000. I found those clamps from Alpha need to be way tighter than a standard clamp, not really sure why - must be due to the width of the band. The clamps that came with the Excel tubes don't need to be nearly as tight to seal, go figure.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Bueller? Bueller?
No one else wants to use it?
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Be interesting to see how many states, sleds and miles that thing has logged.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Such a wonderful thing Beerman did here for us all....Just a reminder to him!
In my best Hank Moody impression, "Much apprec Mutha fukka!"
Dan
Dan
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Bueller? Bueller?
Anyone? anyone?, the holly Smoot Tarriff act, anyone? anyone?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Every single guy in this forum should be taking advantage of this!
The first guy who complains or whines he's not getting enough rpm's or his POS heavy half Arctic Cat falls flat on it's face, we are going to call him "Holly Smoot" from Ferris Beuller's Day Off. Anyone? Anyone?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
We will have to make a HOLLY SMOOT section 'cuz i can just hear the complaining already!
- 15K
