snowdust
Got the tester yesterday. Hoping to test it tonight.
WINDER1987
I'd like to join the line as well thanks
snowdust
Tested mine last night. All was good. Leaks out the BOV as expected above 10 - 12 PSI but I don't plan to change anything for now. Waiting on PM from Rmlise to pass along. FYI - The gauge now reads 8 with no pressure. Still works fine though.
snowdust
@WINDER1987 PM me your info. I haven't heard anything from Rmlise.
snowdust
@WINDER1987 Did you receive the tester? FYI - Rmlise sent me a PM and no longer needs it.
WINDER1987
Yes I did thank you there are 3 of us that are going to use it locally.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Noticed you are from upstate NY and would like to try and get in on this too.Yes I did thank you there are 3 of us that are going to use it locally.
WINDER1987
Message me your info and I will send it to you once we're finished with itNoticed you are from upstate NY and would like to try and get in on this too.
WINDER1987
I just tried it out on my sled it's still stuck on 8 so pumped it up to 20 which would be 12psi and i couldn't get it to hold there without the boot blowing off it with the clamp as tight as I could get it. I have the stock bov and tubes
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
The black rubber boot blowing off the PVC?I just tried it out on my sled it's still stuck on 8 so pumped it up to 20 which would be 12psi and i couldn't get it to hold there without the boot blowing off it with the clamp as tight as I could get it. I have the stock bov and tubes
WINDER1987
Yes my black rubber hose off the sled is blowing off the white pvc that attaches to my hoseThe black rubber boot blowing off the PVC?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
If the unit gets held up to fix a problem, i can send mine out. Let me know
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Take some alcohol or a really good cleaner and clean both the PVC and the inside of your charge tube, sounds to me like you have some oil residue in the charge tube or on the PVC.Yes my black rubber hose off the sled is blowing off the white pvc that attaches to my hose
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I had a thought about the stuck boost gauge, @WINDER1987 can you put some vacuum to the gauge and see what happens? Maybe even pop the gauge's tube off and just use your mouth to see if we can get it back to zero and unstick it.
WINDER1987
I'm working double shifts this weekend. Monday or Tuesday I will try that and report back
- 7K
