Turboflash
- Mar 18, 2019
- Southern MN
One would have to have a very sensitive and very accurate chassis dyno to measure the difference. In the real world, on snow, I doubt anyone could tell the difference. There are many other variables that would make more difference in 1/4 mile or 1000' or even 1/2 mile in a race.If 21/38 is the ratio you are looking for (.55) you may be better off running 25/45 (.56) as it run more efficiently (longer chain, less rolling resistance, greater circumference = less energy wasted). Others here have run that combo.
25/45 is much more expensive to install than 21/38. Technically, on paper, I think a scientist/engineer could prove that you are correct but from a practical standpoint, it would not matter on snow.
earthling
LOL.. yes, well, as an engineer, its just me thinking out loud and yes, I agree.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Turboflash & Earthling....it's all the little
things. Taking advantage of every single angle he can. On paper & at the track. At the end of the day, he's the fastest guy.
That's not me.
That's not me.
Turboflash
- Mar 18, 2019
- Southern MN
LoL - totally agree. I'm not the smartest guy out there so I default to trying to out-power 'em. Hence, PEFI Stage 4 (330 HP pump gas) with option of 360HP with C16 and waste gate lock and high gearing w lots of long studs - 1/4 mile.Turboflash & Earthling....it's all the little
That's not me.
Doc Harley
- Oct 17, 2016
- Here & there
Well....that's too funny. Best answer yet! Lol.LoL - totally agree. I'm not the smartest guy out there so I default to trying to out-power 'em. Hence, PEFI Stage 4 (330 HP pump gas) with option of 360HP with C16 and waste gate lock and high gearing w lots of long studs - 1/4 mile.
I would love to be the guy that outsmarts everyone on Eco trail. But we know how that's goes. I'm the guy on Max 17, balls to the wall, squirting in my last oz of boostane, fighting to stay one ski ahead of the stockers. Lol. Oh well....at least we're having fun!?
NYTurbo
Yeah Scott Taylor gears are a bit pricey for sure
sideshowBob
I have been using Scott Taylor gears and the main reason is my desire to have a 15 wide bottom gear to match the top gear and chain width….but they are not cheap!
Doc Harley
- Oct 17, 2016
- Here & there
Doesn't seem dire to have a 15 wide bottom gear, but do understand your thoughts. Makes sense to me.I have been using Scott Taylor gears and the main reason is my desire to have a 15 wide bottom gear to match the top gear and chain width….but they are not cheap!
Doc Harley
- Oct 17, 2016
- Here & there
NYTurbo, Thank you for getting me the part #'s and source... Quick and painless.Stock gear is 13W on bottom but you could use a 15W if u want. OEM is usually the cheapest
Doc Harley
- Oct 17, 2016
- Here & there
Wrapped that up this morning. Noticed my engagement changed about 400 RPMs higher. I'm assuming because of the gear change, my torque and engagement changed with it?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
A gear change won't affect engagement.Wrapped that up this morning. Noticed my engagement changed about 400 RPMs higher. I'm assuming because of the gear change, my torque and engagement changed with it?
Doc Harley
- Oct 17, 2016
- Here & there
Hmmm......what about switching from an XS825 back to a 8jp?A gear change won't affect engagement.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Maybe, is the 8JP a little thinner than the XS 825? That would make a difference if the distance to the sheaves has changed.Hmmm......what about switching from an XS825 back to a 8jp?
Like DMC says, gears wont make any difference.
Doc Harley
- Oct 17, 2016
- Here & there
I'm sure you're correct. Belts are definitely different dimensionally.Maybe, is the 8JP a little thinner than the XS 825? That would make a difference if the distance to the sheaves has changed.
I ended last year with a XS825, and I'm going to start this season on the 8jp.
While the 8jp won't be as durable as the XS825, I read past posts where the 8jp is more consistent and crisper throttle.
As long as I don't max out my qay70s. If that makes sense.
