Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Durability aside, isn't the 8jp and all around better performer?Tune to the xs825 forget the 8JP
NYTurbo
Not in my opinion.
Doc Harley
- Oct 17, 2016
- Here & there
Surprisingly, this low mileage DMC top gear has some play it in.
And lastly, it there a set amount of clearance between new chain & tensioner? When I run the adjuster in until its finger tight and then back it out one and a half turns it's still basically on top of the chain. Where is my old chain had clearance between itself and the tensioner
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
tighten bolt by hand till snug, then back out the 1-1.5 turns, if you have roller or skate they always ride on chain, oil stops the wear.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
The only time I use the 8JP belt is on warmer days when trying to find some quick RPM. The 8JP will run a couple hundred RPM higher than the 825
The 825 grabs better and is less "dusty"
Doc Harley
- Oct 17, 2016
- Here & there
I'll scope things out. I might have to use the XS belt for tuning, as I may run out of adjustably with qay70's. Bigger tunes will put me at 76/77g +/-.The only time I use the 8JP belt is on warmer days when trying to find some quick RPM. The 8JP will run a couple hundred RPM higher than the 825
